PLANNING & PROGRAMMING of Construction Activities(C.P.M , PERT & BAR CHARTS )
Pawan Dhagate
Construction industry is essentially a service industry .Construction activity involves converting the specified plan prepared by an engineer or architect into a finished project.Every project is different ,the problems faced are also different . In construction business even one problem may prove costly as the concerned personnel may never have encountered it before . Hence internal planning must be treated seriously and efforts should be taken to anticipate problems before construction of the project begins .The Construction planning of the project may be divided into three parts and are
* Material
*Labour force (Manpower )
*Finance required for material and labour as well as equipment ,supervision and over heads . Here We have made small attempt to understand the use of ADVANCE PLANNING AND PROGRAMMING AS its the key to better management and execution of a project . Many of the new site engineers may find this helpful as you go through this big subject .
Kindly share your reviews and comments to discuss it further broader aspects in details .
regards
Team Civil4m
  • CONSTRUCTION SCHEDULE.pdf
* Material
regards
Team Civil4m
Good information
If you can post any example of real time project what executed it will be so helpful
* Material
regards
Team Civil4m
GREAT! THANKS!
