PLZ POST NEW DESIGN CALCULATION SHEET ,SHOWING ERROR IN POSTED SHEET.(CONCRETE MIX DESIGN SHEET)
SHOWING ERROR IN ADMIXTURE DOSAGE AND GRADATION RATIO
Admixture is selected as yes then you need to write the required details of the admixture in sheet, else it will show error.
Gradation ratio - what error it is showing.
It will be more helpful in understanding problem you are facing, if you share the screen shots of the same.
Note: only do enter the data in cells where it is required, editing the other cells might lead to error if that cell contains a formula for doing calculations.
