Admixture is selected as yes then you need to write the required details of the admixture in sheet, else it will show error.
Gradation ratio - what error it is showing.
It will be more helpful in understanding problem you are facing, if you share the screen shots of the same.
Note: only do enter the data in cells where it is required, editing the other cells might lead to error if that cell contains a formula for doing calculations.
