Question UG tank excavation process in wet land ?
shantunu
3
IRELAND
Can anyone suggest me the best and safest way to excavate earth for placing UG RCC tank(precast) having a depth of 6 mtr, (16x10 mtrs) on wet land ? I have prepared a plan with 35 deg cut and 45 deg cut for the stability and safety in which lot of extra excavation to be done. Is anything else we can go which would be cost as well as time effective ?
Jayant Joshi
Premium Member
Mar 15, 2018
84
55
Valsad
Dear
please reconfirm the dimension is 16 m X 10 m X 6 m deep
The tank is RCC precast
And you are going to place it under ground in wet land.
Last year we have constructed UG RCC tank of size 30 m X 20 m X 6 m
Raft thickness is 1.0 m at around wall and 500 mm thick at center portion
Wall thickness is 900 mm at bottom and 300 mm at top
Design criteria is tank is empty and only outer load is active.
shantunu
3
IRELAND
Dear
The size is as you said and its a precast one. With help of boom crane (80 MT) we will place it in the position. For us vital is its safe excavation. What surface preparation with dewatering ,pumping and sheeting we can do while excavating ??
Eternal Member
2,632
4,580
Pune
Hopefully by now you may have finalised and even executed the work.
For doing safe excavation, sheeting or piling around the plot is good option along with keeping continuous de-watering.
I do not have much experience in such work nor have any idea about soil properties you are dealing with in that wet area, so cant comment on anything much.
If you had made strategy for it and done the work, request you to share with others by creating new post in Site Engineering & Execution
Add some details and photographs so that it will help others to get knowledge of such activity.
