Mr. Prakash, can you describe the situation you are dealing with? Do you have a picture of the condition to share? Providing context to a problem is necessary in order for solutions to be conceived, developed, weighed & optimized. Cheers!!
The leakage first starts with cracking in concrete or improper compaction which leaves pockets and honeycomb in the structure which are not visible.
Also leakage could occur from cutouts area which are placed in structure, the hanging shutter supporting batten which are resting on slab in case of sunk slab, if not remove and filled with concrete could also lead to leakage source.
Below articles could help you in eliminating shrinkage cracks.
Shrinkage cracks in concrete Shrinkage cracks in concrete generally occurs during fresh state of concrete usually within 1 to 2 hours of placement (when water from concrete evaporates from the surface). They varies in width from hair line to 3mm in width and from few centimeters to a meter in...
Precautions to minimize Plastic Shrinkage Cracks: The Plastic Shrinkage cracks occur on the surface of freshly placed concrete during finishing or soon after. In plastic concrete bleed water surfaces due to gravity. If the accompanying settlement is...
